843 - jacking or blocking points
donald73d
I put some wooden blocks below the front chaincase reservoir. Three inches under the drain plug. I need to get the front tires off the ground and lifted the machine with the bucket and then blocked it. I assume that area is strong. What about the back under the engine? Can I jack or block anywhere back there or are there specific jacking points?
I jack it up from the middle of the belly pan front or back depending on where i need to get to. Then block it from the axle tubes.
