Mahere
- Joined
- May 3, 2016
- Messages
- 3
I have an older bobcat 843, I have gone through and done a total rebuild of the engine. When I wend to put it back in I also put in a new u-joint connection between the pump and the engine "per a recommendation from bobcat that no one ever greases the joint". The engine runs great but I started to use the machine and I am getting the high pitched low fluid squeal, and shortly after that turned into a knocking and clunking. The machine looses power and sounds so horrible I am trying not to run it much. I thought the joint went bad but it did not. In the process of rebuilding parts of this machine I drained and cleaned the hydraulic tank, installed new fluid and filters. From a few things I read on here I am leading to a need a new pump does any one have any thoughts?
