Bobcat Skidsteer Forums
843, charge light on
Reply to thread
Message
<blockquote data-quote="OldMachinist" data-source="post: 42738" data-attributes="member: 437"><p>I'll add one more possible cause. Left side motor and drive chain bad, moved right side motor to the left and chain still bad so no movement. Bad left side motor now on right side and no movement.</p><p> Put a gauge in the charge pressure port and verify low pressure.</p><p>843 charge pressure</p><p>Serial number 12999 and below 120-140 psi</p><p>24001 and up 180-200 psi</p></blockquote><p></p>
[QUOTE="OldMachinist, post: 42738, member: 437"] I'll add one more possible cause. Left side motor and drive chain bad, moved right side motor to the left and chain still bad so no movement. Bad left side motor now on right side and no movement. Put a gauge in the charge pressure port and verify low pressure. 843 charge pressure Serial number 12999 and below 120-140 psi 24001 and up 180-200 psi [/QUOTE]
Verification
Post reply
