Bobcat Skidsteer Forums
825 Hydraulic Drive Issue
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 73018" data-attributes="member: 82"><p>Use a wrench, mark the hoses. I used a centre punch so i knew what went where. I'd advise using plugs and not rags for the hoses. Rags can be forgotten and sucked into the system.</p><p>While the pump is out, you may want to check for any wear that you can access easier with the pump out.</p></blockquote><p></p>
[QUOTE="Tazza, post: 73018, member: 82"] Use a wrench, mark the hoses. I used a centre punch so i knew what went where. I'd advise using plugs and not rags for the hoses. Rags can be forgotten and sucked into the system. While the pump is out, you may want to check for any wear that you can access easier with the pump out. [/QUOTE]
Verification
Post reply
