Bobcat Skidsteer Forums
825 bobcat added electric fuel pump
Reply to thread
Message
<blockquote data-quote="skidsteer.ca" data-source="post: 22186" data-attributes="member: 307"><p>Yes, put a boat primer bulb above the blue pump, one you prime the fuel to it you willbe all set. You might want to use the regulator that came with them to as they produce about 20 psi.</p><p>As for the small elecrics the motor is pulsing a diaphram and a series of one way check valves force the fuel forward. They are not known for long life, though the flow would be a better match for a 40 to 50 hp diesel then the blue Holley with 110 gph.</p><p>Ken</p></blockquote><p></p>
[QUOTE="skidsteer.ca, post: 22186, member: 307"] Yes, put a boat primer bulb above the blue pump, one you prime the fuel to it you willbe all set. You might want to use the regulator that came with them to as they produce about 20 psi. As for the small elecrics the motor is pulsing a diaphram and a series of one way check valves force the fuel forward. They are not known for long life, though the flow would be a better match for a 40 to 50 hp diesel then the blue Holley with 110 gph. Ken [/QUOTE]
Verification
Post reply
