Other Brand Skidsteer Forums
GEHL Skidsteer Forum
7800 can't get son of a bitch started
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 33577" data-attributes="member: 82"><p>The battery needs to be good to spin the engine as fast as possible to get the air pocket to get super heated. The smoke colour gives ideas of whats going on too. White is un-burnt fuel, black is incomplete burning of fuel.</p><p>I'm a bit concerned with the watery black sludge though. It shouldnt' be wet at all.</p><p>The tap off line is for internal leakage of the injectors, its totally normal. It will also lubricate the internals of the injector.</p><p>Get your battery charged up, even use a car with jumper cables if you can, get all the power to it you can to get it spinning nice and fast. There should be something to heat the air going in, be it glow plugs or a grid that warms the air coming in.</p></blockquote><p></p>
[QUOTE="Tazza, post: 33577, member: 82"] The battery needs to be good to spin the engine as fast as possible to get the air pocket to get super heated. The smoke colour gives ideas of whats going on too. White is un-burnt fuel, black is incomplete burning of fuel. I'm a bit concerned with the watery black sludge though. It shouldnt' be wet at all. The tap off line is for internal leakage of the injectors, its totally normal. It will also lubricate the internals of the injector. Get your battery charged up, even use a car with jumper cables if you can, get all the power to it you can to get it spinning nice and fast. There should be something to heat the air going in, be it glow plugs or a grid that warms the air coming in. [/QUOTE]
Verification
Post reply
