Other Brand Skidsteer Forums
New Holland Skidsteer Forum
7775 JD circuit board interchangeable w/NH
Reply to thread
Message
<blockquote data-quote="Morel1" data-source="post: 62103" data-attributes="member: 8288"><p>I was told that the starter relay is in the instrumentation board. I'm up and running. After getting an updated installation instruction guide and with the help from some fine JD service managers, I was able to find my voltage signal problem and get the board to accept all the setup parameters. I would still like to know if the board is the same and only differs by the engine code setup. If NH uses numbers other than 02 or 06 for the code it might be possible. I went with better safe than sorry. Could not find anyone who did this only guesses.</p></blockquote><p></p>
[QUOTE="Morel1, post: 62103, member: 8288"] I was told that the starter relay is in the instrumentation board. I'm up and running. After getting an updated installation instruction guide and with the help from some fine JD service managers, I was able to find my voltage signal problem and get the board to accept all the setup parameters. I would still like to know if the board is the same and only differs by the engine code setup. If NH uses numbers other than 02 or 06 for the code it might be possible. I went with better safe than sorry. Could not find anyone who did this only guesses. [/QUOTE]
Verification
Post reply
