Bobcat Skidsteer Forums
7753 hydraulics locking up on lift only
Reply to thread
Message
<blockquote data-quote="shawnjs" data-source="post: 55323" data-attributes="member: 7295"><p>Thanks again for the help guys, this forum has lots of great info. It turns out it was a bad solenoid and valve for the lift only. It was only getting intermitent voltage because i had a bad safety bar sensor that was only supplying it 5-7 volts, not the 12 required. As soon as I replaced the Safety bar sensor it was supplying the required 12 volts and fried the solenoid melting it to the valve itself. Im guessing here but assuming the low voltage being supplied by the bad bar sensor caused the solenoid to work twice as hard and wore it out prematurly. Installed a new solenoid and valve and it works like a champ now. Thanks again, Shawn.</p></blockquote><p></p>
[QUOTE="shawnjs, post: 55323, member: 7295"] Thanks again for the help guys, this forum has lots of great info. It turns out it was a bad solenoid and valve for the lift only. It was only getting intermitent voltage because i had a bad safety bar sensor that was only supplying it 5-7 volts, not the 12 required. As soon as I replaced the Safety bar sensor it was supplying the required 12 volts and fried the solenoid melting it to the valve itself. Im guessing here but assuming the low voltage being supplied by the bad bar sensor caused the solenoid to work twice as hard and wore it out prematurly. Installed a new solenoid and valve and it works like a champ now. Thanks again, Shawn. [/QUOTE]
Verification
Post reply
