Bobcat Skidsteer Forums
773g slower forward than reverse
Reply to thread
Message
<blockquote data-quote="mrfixitpaul" data-source="post: 36847" data-attributes="member: 2582"><p>If all the linkages are still tight, probably the steering levers have been bent toward the front of the machine. If the machine is not 'creeping' then you don't need to mess with the pump shaft levers, just adjust the length of the flatbar linkages until the speeds are more balanced, forward vs. reverse.</p></blockquote><p></p>
[QUOTE="mrfixitpaul, post: 36847, member: 2582"] If all the linkages are still tight, probably the steering levers have been bent toward the front of the machine. If the machine is not 'creeping' then you don't need to mess with the pump shaft levers, just adjust the length of the flatbar linkages until the speeds are more balanced, forward vs. reverse. [/QUOTE]
Verification
Post reply
