773G Kubota engine and pump removal
andyjax
Hello all- Getting ready to remove my engine/pump on the 773G. Engine is the Kubota 4 cylinder and has the lift points bolted to the head. Are these safe to use for the entire engine/pump assembly or should I use something else? Any other gotchas to watch out for appreciated. Thanks!
The removal section of the book (which is available in the manual thread) seems to indicate this. It also has the specs for a lifting fixture that aids in removing it, as a conventional load leveler won't fit in the close confines.
