I'm having issues with my 773G with about 1790 hours. Used machine in April, parked in garage, went to use it and it started and died. Wouldn't re start, so I started diagnosing. Fuel pickup in tank broke so I replaced it. Charged the battery, started up, used for 3 hours, shut machine off with key and wouldn't start...started diagnosis again...Replaced fuel pickup tube, fuel lines and clamps, primer bulb, transfer pump, still no start. Put a clear hose from transfer pump to fuel pump, primed fuel system, and started engine...runs and stops after a few minutes. Fuel eventually runs back down hose and it quits running. Removed injectors and had tested at dealer shop. #1 was not spraying right, and all injectors didn't pass pressure check. #1 was missing heat shield and copper seal...had injectors rebuilt and tested and reinstalled. Did compression test before and have 540-550 psi in all cylinders. I installed an electric lift pump in the system as well. Started machine and it ran for 15 minutes and stalled when I tried to move it. Machine still doing the same thing! Won't keep prime and stalls after a few minutes....fuel runs back down towards transfer pump....I'm stuck and need help!
