773 turbo issues
Bschuette
when the machine has a hard jolt such as hitting a crack in concrete with bucket when plowing or banging the arms down fast. the machine will just instantly shut off. all your need to do is re key the machine and it will fire right up . like it looses power instantly. any ideas? no codes either.
Check all of your electrical connections. Clean and tighten the battery cables and all grounding points. Also, check the cables coming from the battery for damage.
You may have a loose connection or bad cable that is disconnecting with a large jolt.
