773 stranded with no power. Help!
I've checked all fuses and relays in the fuse box.
Update...hit the yellow button this morning for the hell of it and it fired right up with no problems....so typical. This is good so I can at least move it but I'm worried it will happen again. Obviously a loose connection but where? Checked everything I can think of.
Wiring is my most likely guess, 7lbs is thinking of the same wire I am. Swapping a key switch will not help you because the dash option has to changed in controller with the service software.
