773 parking brake
brentley
i have a bobcat 773 the parking brake doesnt release. All of the fuses are good and also the relay i connected the brake solenoid to the fuel shut off wiring so i know its good. Now if i take the relay off and jump power from the white wire to the org/wh wire it pulls the solenoid back. Now the question is why am i not getting power to the solenoid to disengage it? It does not have a push to operate button on it i was told that this conversion may fix it is that true? Any help will be very helpful and thanks in advance.
Since it doesn't have the “push to operate” upgrade then it still has a seat switch that may be causing the problem. Look at the BICS box and see which lights are on while sitting in the seat with the lap bar down.
