Bobcat Skidsteer Forums
773 no steer left side
Reply to thread
Message
<blockquote data-quote="Bobcatdan" data-source="post: 66757" data-attributes="member: 7339"><p>First check out the linkage making sure everything is fine there. Next put the unit on blocks. Remove and cap the drive motor hoses on the bad side. Start the unit and run the drive. If the engine pulls down under load, the pump is good. I think your is the current vintage for o ring failures causing loss of power. Reseal motor be on your way.</p></blockquote><p></p>
[QUOTE="Bobcatdan, post: 66757, member: 7339"] First check out the linkage making sure everything is fine there. Next put the unit on blocks. Remove and cap the drive motor hoses on the bad side. Start the unit and run the drive. If the engine pulls down under load, the pump is good. I think your is the current vintage for o ring failures causing loss of power. Reseal motor be on your way. [/QUOTE]
Verification
Post reply
