773 leaking Hydraulic fluid
Wahl0001
My 773 leaks hydraulic fluid out of hole near the rear axel, (on the underside of the skidsteer, was a slow leak, only sometimes, especially when its cold), recently I started up the bobcat and it started gushing fluid out of the same spot(in 10 below weather). Any ideas where i should start or what it might be? I have not started it up since.
farmshop
The hole is probably just a hole into the belly of the machine. I would start by tipping the cab up and look around. Probably a hose leaking. The right side as you are in the machine has your main control valve. The spool valve could be leaking also. If you can raise the arms and put the boom stop in it makes repairs easier. There is also a access panel between the tires that can help
