Hi, been using this site for info for a few years now, but have never had to post a question till now. My 1997 773 has front hydraulic controls on the right stick, and they have never worked. The lights on the right panel used to function, but no longer do. So, I have a need for a grapple bucket and started to trouble shoot the system. Fuses all good, relays all good. I checked the two switches for operation at the plug, and good there. It seems that the system isn't getting any power, which wire would I check? I pulled the harness, cleaned the plug ends and coated with dielectric grease. Had to solder 2 spots that were rubbed bare. There is a small epoxy coated circuit board behind the left stick, could this be bad, or can it be tested? So after putting it all back together, I still have no front hydraulics. But, now my lift arms and bucket won't operate either. So I obviously opened a can of worms. The lift arm light on the bics is flashing once. I unplugged everything one by one, but can't get it going. I have always had to hit the trac lock override button to drive the machine (another story) but still no lift or bucket function. Any ideas? I'm reaching the end of my patience for tilting the cab up and down while chasing my tail..
