773 G series shut down
lionheart
Recently my display would only show the bottom half of the hours when key was turned to on position and only show the top of the hours while running. Now it shuts down and shows low hydro pressure. Any help would be appreciated
The machine shuts down when the charge pressure is too low to prevent damage to the pumps. This can be caused by many problems, on the common list is plugged hydraulic filter, contaminated hyd oil, incorrect pressure reading cause by a faulty sensor and the list goes on.
Search “charge pressure” and read up, but do get it fixed.
Could be a as simple as the hyrdraulic pump's drive belt becoming too loose or broke as that will flash the hydraulic charge pressure code after start up and shut down the machine in a few seconds , does it lift the boom or move during the time it is running---------I seen the hours do what you are mentioning before and a new screen was the way to fix it , the new screen has been redone and looks totally different , I think it's easier to read ---the old scren , which I presume is the one you have , had a light bulb in it that is replaceable , and the plastic bulb holder of the dash bulb is made of plastic and breaks up and can be bugt as a pigtail , it isn't your problem of half the numbers displaying , but thougt I'd pass it on to any others on the thread
Nothing works before the beeps and the shutdown process. I took apart the display. That was a bugger. It had screws, plastic clips and gasket sealer. Nothing jumped out at me. Where is the hydrolic sensor?
