Bobcat Skidsteer Forums
773 Control Valve
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 99747" data-attributes="member: 82"><p>Glad it's working as it should.</p><p>The only thing i'd do is check the relief pressure setting, you have gone this far, it won't hurt to hook a gauge to your an aux hydraulic connector and see what you get. I don't know what your machine is meant to put out, but it should be in the high 2,000 psi range.</p></blockquote><p></p>
[QUOTE="Tazza, post: 99747, member: 82"] Glad it's working as it should. The only thing i'd do is check the relief pressure setting, you have gone this far, it won't hurt to hook a gauge to your an aux hydraulic connector and see what you get. I don't know what your machine is meant to put out, but it should be in the high 2,000 psi range. [/QUOTE]
Verification
Post reply
773 Control Valve
