I SUPPOSE AND FOREMOST IS THE SAFETY CONCERN,,,,, you cant be dropping loads. you cant have buckets fallining off. bad **** happens quick. refuse to operate until problem repaired. easy fix remove pwr bob cyl cap lines #6 caps and plugs . go back to manual. don't get hurt don't hurt knobody else. TAG UNIT OUT DO NOT OPERATE> this cant be stated serious enough. it happens quick. catching a 150lbs bkt with 2yards of material in it does not bode well for the catchee. let alone the the fact that you there was problem . and you yes you are personally resposbile. for letting it go
