Bobcat Skidsteer Forums
773 bobcat steering problem
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 64486" data-attributes="member: 82"><p>Lift the cab, look at the drive motors, follow the small hose back to the pump and oil tank. There will be alloy canisters, these are the sace drain filters.</p><p>It could also be as simple as bad seals in the drive motors. If the case drain filters are ok, you can swap drive motors and see if the problem moves. You can some times swap these hoses at the pump, but the older they get the stuffer they get and it can be really difficult to swap them over.</p></blockquote><p></p>
[QUOTE="Tazza, post: 64486, member: 82"] Lift the cab, look at the drive motors, follow the small hose back to the pump and oil tank. There will be alloy canisters, these are the sace drain filters. It could also be as simple as bad seals in the drive motors. If the case drain filters are ok, you can swap drive motors and see if the problem moves. You can some times swap these hoses at the pump, but the older they get the stuffer they get and it can be really difficult to swap them over. [/QUOTE]
Verification
Post reply
