763 Water temp sensor location
socal50
Hey everyone, I am the proud owner of a 763! Love it, but the temp gauge does not work. I pulled the gauge out and grounded the purple wire behind it to ground and the temp reads red hot (I think the gauge is OK). My problem is I am looking to test the temp sensor and I can't find it anywhere. I am looking all over the thermostat housing, the water pump housing, etc... where is this thing? A picture would be amazing, no description has led me to it. Thanks is advance.
Should be located on the 'front side' of the block, towards the top. Front being the side closest to the loader. Right side if sitting in the machine. If you follow your lines for your cab heater it should bring almost right to it. Single purple wire running from it to the wiring harness.
