763 Water Temp Indication
nwilson
My 763 has the BOSS indicating system which seems to be functioning normally with the exception of the water temp indicator. It never indicates more than 2 "bars" on the scale. I found the thermostat had failed (open) and replaced it with a Kubota part (160 degree) and was sure that would solve the problem. Nothing has changed. When I start it cold it shows one bar and after use it shows 2 bars. Is this normal or do I need to invest in a new temp sensor? Thanks in advance!
BOSS Water temp Guage
1 Bar cold to 190degrees
2 Bar 190 to 198
3 Bar 198 to 204
4 Bar 204 to 210
5 Bar 210 to 217
6 Bar 217 to 224
7 Bar 224 to 231
8 Bar 230 on up warning sounds
235 engine shutdown
Thanks for the reply! I had found that thread and it left me scratching my head. I could understand those gradients if the engine was designed to run warmer but with a 160 degree failsafe thermostat and a low coolant level monitor it seems like the temp gauge is of little use. Did Melroe really set it up that way?
