763 tilt not working lift is fine
Robinson
Good morning guys I’m having an issue with a 763, the lift world fine but the tilt will not work at all. This is a model with the foot pedals for the lift and tilt function. Any ideas?
Sounds like an actuator is gone bad.
Try swapping the plugs to the actuators to see if the tilt then works, and the lift doesn't.
Good morning guys I'm having an issue with a 763, the lift world fine but the tilt will not work at all. This is a model with the foot pedals for the lift and tilt function. Any ideas?
Check all of the linkages from the pedal to the pump and see if anything is loose, damaged or worn out.
foot control valves are pretty basic, sounds like linkage or pin to valve fell out, maybe a cotter key rusted off and pin fell out?
