763 Steering adjustment ?
Yes just block it up good to ajust so you don't run yourself over and get any creep out while your in there
linkage on the steering arms I would assume ?
As the linkage bushings wear, the travel on the sticks changes and they can bottom out on the metal part that the steering levers pass through. If changing the bushings doesn't do the job, you can loosen the bolts that are under the seat and adjust it. If you shorten them, it should give you more travel to go forward i think.
It's not too hard to do.
great info thank you !
