Bobcat Skidsteer Forums
763 squealing underload
Reply to thread
Message
<blockquote data-quote="skidsteer.ca" data-source="post: 19179" data-attributes="member: 307"><p>Your main drive belt is loose or needs replaced. The have a spring loaded adjuster but once it adjusts so far the spring needs to be re wound again. Of course if oil got on the belt that won't help things either. hse are simple to adjust and give the exact simtoms you describe. Applys to all bobcats with the motor in sideways</p><p>Ken</p></blockquote><p></p>
[QUOTE="skidsteer.ca, post: 19179, member: 307"] Your main drive belt is loose or needs replaced. The have a spring loaded adjuster but once it adjusts so far the spring needs to be re wound again. Of course if oil got on the belt that won't help things either. hse are simple to adjust and give the exact simtoms you describe. Applys to all bobcats with the motor in sideways Ken [/QUOTE]
Verification
Post reply
