763 Late 90's Help Me Please
JackSkid
Hello, I have a leak on the right side lift cylinder (return hose) on my 763. It is pretty obvious where the hose needst go in the cylinder. I have not been able to find an access panel to the other end. Si I can replace the hose. Could anyone tell me how to access this area so I can replace the hose. Thanks
On most Bobcats you can see where the other end of the hose connects to the steel lines from inside the engine compartment. Open the engine door and have someone wiggle the hose and you should see which one it is.
Thanks for your reply. I can see it but appears to be behind the hydraulic filter assembly and can't get to it. Looking for an acces panel
There isn't an access panel, you need to get in behind the filter and crack the lines there. Sadly, there is no other choice, its not fun with access, but it can be done, i have done it a few times. I actually removed the coolant bottle and bracket to gain access. Hopefully yours is the same basic setup.
