I recently purchased a 763 Bobcat that had been obviously mistreated and poorly maintained but I already owned a 751 so they matched up for parts exchange fairly well! I inspected and transported the 763 to my farm where I began my process of power washing and servicing my 763. When I had unloaded the machine I found about 1/2 gallon of hydraulic fluid all over the trailer and inside the engine compartment and was highly concerned. My initial trouble shooting found that the previous owner had cut a 1/2 inch hole in the hydraulic fill cap? This sent alarms as I expected the machine had been starving for hydraulic oil at some point! I open the cab and remove the side inspection covers and found a full cavity of mud, grease and oil saturated! What a mess! I pressure washed for three hours and finally could see the hydraulics on each side and the mess removed. At this point I found the culprit causing the hole in the hydraulic cap! The hydraulic tank vent cap was totally covered with 1/4 inch of hydraulic oil saturated dirt causing no venting to occur. I replaced the hydraulic fill cover and cleaned the vent cover and ordered a new one. This cap needs maintained on a frequent basis!
