[email protected]
- Joined
- Jan 30, 2017
- Messages
- 1
Could someone please tell me where to hook up the two hoses from cab heater to engine, what fittings...type, size, shut off valves etc.. Pictures would be greatly appreciated. Thank you.
Pretty sure you install the hoses in place of the by-pass hose that is mounted to your thermostat housing. Look at the engine, find the upper radiator hose and you will see a small L shaped hose, this is the one you want to remove and put the two hoses from the heater in it's place.Hey, sounds like you're adding a heater! I'd like to do that too, since on my 763 there is no fuse panel between the operator's feet. What are you using for the heater? I haven't found a cheap solution that I thought would work yet. And I don't know where the hose hookups would be on the Kubota 2203 engine, I haven't looked for that spot yet. There are other posts on here where folks have added a heater, so just search around and see what you turn up. And welcome to the forum, lotsa good advice here!---Bobbie-G
