Bobcat Skidsteer Forums
763 G V2203-E engine removal question?
Reply to thread
Message
<blockquote data-quote="m610" data-source="post: 32691" data-attributes="member: 372"><p>The best way is to lift the cab and remove the fan assembly by the 4 bolts that hold it to the upper frame. With it gone you have plenty of access to the engine area. It is not necessary to lift the cab to remove the engine once it is unbolted. You can unbolt the belt/bellhousing from the hydraulic pump but you would also have to remove the pulley to free it from the engine assembly. Best bet is to pull it all out. You can do it without the special lifting fixture, by sliding the engine out on wood.</p></blockquote><p></p>
[QUOTE="m610, post: 32691, member: 372"] The best way is to lift the cab and remove the fan assembly by the 4 bolts that hold it to the upper frame. With it gone you have plenty of access to the engine area. It is not necessary to lift the cab to remove the engine once it is unbolted. You can unbolt the belt/bellhousing from the hydraulic pump but you would also have to remove the pulley to free it from the engine assembly. Best bet is to pull it all out. You can do it without the special lifting fixture, by sliding the engine out on wood. [/QUOTE]
Verification
Post reply
