Bobcat has been sitting for about a month. I tried to start it battery dead. Tried to use jumper box still no start. Replaced battery with new one. Had to change routing of battery cables slightly but everything hooked up. Started right up. Lowered the bar and the bar light came on. Pushed the push to operate and the lights came on except the tile/lift light. No codes shown. The seat bat light comes and goes when you raise and lower the bar. I charged the old battery and it started at 5 volts and charged to 13.9 and held. I hooked a load and it tested good the day I removed it from the charger. Not sure if battery was bad or had something discharge it. It has sat for months and started right up so never had a drain before. Looking for suggestions. I have checked and cleaned the fuses in box between feet, cleaned the grounds near the battery where the ground attaches to the motor. Cleaned the positive connection at the starter. It has foot and hand controls and the foot pedals are locked solid so not releasing the spool. It appears the solonid has 3 wires. Is it possible to jump the wires to be sure the solonid is working? Can the seat bar switch be bad and still turn off the light bar light and unlock the brake and not unlock the tilt? Thanks in advance for any help
