Jeffscarstrucks
- Joined
- Nov 24, 2007
- Messages
- 92
I have a friend whos machine melted the charging wire between the alternator and the starter with no obvious shorts or noise from the alternator. The machine is on his property some miles way and I have not seen it first hand. It also took the two small wires with it where they were close to the large wire and the machine stopped when this happened. He unhooked the battery (VERY quickly) and looked for other damage but there was none...no fire luckily. Unhooked the large wire from the starter, seperated the small wires and reconnected the battery. The machine started and ran with no noise from the alt (bearings OK should equall no short??) and drove back to the shop. I am trying to help with a long distance diagnosis so I will say thanks in advance. You all helped me get my old ASV up to speed and I really appreciate the help, JEFF P.S. Any tricks to access the alternator to remove it so that it can be bench checked?
