Bobcat Skidsteer Forums
763 bucket wont raise up?
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 38748" data-attributes="member: 82"><p>If its a BICS machine, look at the box on your.... Right side when sitting down? Check all the lights are on, if it detects the seat bar or seat sensor is not activated it won't unlock.</p><p>If it drives when you press the traction lock overide button, i'd suspect a sensor.</p><p>Sorry i can't give you better advise, you can lift the cab and check for power at the coil too, if you power it with 12V it should have a tiny click and the lift/tilt should operate.</p></blockquote><p></p>
[QUOTE="Tazza, post: 38748, member: 82"] If its a BICS machine, look at the box on your.... Right side when sitting down? Check all the lights are on, if it detects the seat bar or seat sensor is not activated it won't unlock. If it drives when you press the traction lock overide button, i'd suspect a sensor. Sorry i can't give you better advise, you can lift the cab and check for power at the coil too, if you power it with 12V it should have a tiny click and the lift/tilt should operate. [/QUOTE]
Verification
Post reply
