763 Bobcat Questions
Ralph123
I have a 763 Bobcat. Have always had problems with the battery posts coming loose so finally reversed the battery and put new battery posts and leads on. At the same time changed all the fluids but now a couple other problems have started. When I go to start it the glow plug counter doesn't always turn on and the error light lights up. I turn the key off and on a couple times and then the glow plug counter starts up. The other problem is that I push the start button on the electrical panel and it starts to work but then the lights go off and the machine wont work. After it warms up it works fine. Is this normal? I undid the wiring harness in the seat bar arm and sprayed electrical cleaner but this didn't seem to fix anything.
