Bobcat Skidsteer Forums
763 BobCat Float Detent
Reply to thread
Message
<blockquote data-quote="skidsteer.ca" data-source="post: 33550" data-attributes="member: 307"><p>They are cheap to fix and not hard to figure out, just a major PITA to get the new detent balls back in there. Parts are about $5. Be sure to buy extra little balls as you will launch them everywhere on each unsucessful attempt.</p><p>Seen as your is working leave it alone or maybe try some spray lube inside the cap without removing it enough to let the balls escape.</p><p>Ken</p></blockquote><p></p>
[QUOTE="skidsteer.ca, post: 33550, member: 307"] They are cheap to fix and not hard to figure out, just a major PITA to get the new detent balls back in there. Parts are about $5. Be sure to buy extra little balls as you will launch them everywhere on each unsucessful attempt. Seen as your is working leave it alone or maybe try some spray lube inside the cap without removing it enough to let the balls escape. Ken [/QUOTE]
Verification
Post reply
