753g heat install???
bobcatgrant
I would like to install an aftermarket heater in my 2002 753g series. Ive seen the posts on the web how easy it is and blah blah blah. My question to you Bobcat guys is where do i hook this thing up? I see the Bobocat has an adapter plate that mounts under the thermostat housing. Is that something i need? Also bobcat says in its parts fische that the 180 tstat is needed if you didnt have cab heat from factory. Is this needed also and if so, does it have to be a genuine bobcat part since the motor is Kubota (i.e get it from an auto parts store) The project seems easy enough just want to make sure i know what to do before i start. Thank you in advance!
