Bobcat Skidsteer Forums
753 right side forward drive problem
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 16103" data-attributes="member: 82"><p>Your dealer has seal kits, they are around $70-100. If your backup rings aren't broken you can just replace the O rings, my 753 needed $11 worth or O rings to replace the whole lot. $22 for both sides, you can't beat that. But when you open the motor you will see 3 backup rings made of plastic, the book said not to re-use them but i did and they work 100%.</p></blockquote><p></p>
[QUOTE="Tazza, post: 16103, member: 82"] Your dealer has seal kits, they are around $70-100. If your backup rings aren't broken you can just replace the O rings, my 753 needed $11 worth or O rings to replace the whole lot. $22 for both sides, you can't beat that. But when you open the motor you will see 3 backup rings made of plastic, the book said not to re-use them but i did and they work 100%. [/QUOTE]
Verification
Post reply
