753 Oil Pan Orientation
DaleM 753
Hi All, on a 753 machine (508613xxx), the oil pan is typically shown on the Parts Diagram with the middle drain port facing forward and the side drain port facing off of the right side (from rear of machine facing forward) of the engine. My pan was installed in that orientation. I have a new pan arriving today (leak issues with old one) and will be putting things back together. My question is: Are there any reasons why the pan cannot be re-oriented 180 degrees such that the middle drain port comes off the back of the engine vs. being hidden and unusable on the front of the engine? From everything I can see, the pan appears to be symmetrical. Having the middle drain out the back may allow me to simply use it for oil changes and eliminate the little drain hose off the side of the pan (and potential issues with it). Thoughts? Thx, Dale M
I would say that it would be probably possible, but does it make sense probably not. You would not be able to reach the drain plug because it is between the engine and pumps.
I have a 763 which has the same engine, so I’m picking up what you’re putting down and understand what you’re trying to achieve, but knowing engineers I’d be very surprised if they’d allow you to simply flip the pan around as they’d be going against their own mantra. 😜 Let us know how you get on.
