- Joined
- Jun 30, 2009
- Messages
- 93
Trying to address some performance issues with my hydraulics. Rebuilt the lift arms last week. Looking at the hydraulic fluid coming from the lifts, I could see very small metal flakes in the oil as the container was sitting in the sun. These were not chunks, but rather a dust sized mixture. I know this isn't good. Planning to pull the engine and hydrostatic / hydraulic pumps. I know one if not both of these are in need of replacement or rebuilding. So first off, Mr. Tazza, I saw in another post you may have a source for replacement parts. I have Sauer / Sundstrand pumps in this unit. Would your source have parts for this brand? Secondly, and most important: What process can i use to clean out the rest of the system? I've read about pumping out through AUX but that is probably not going to remove all the particulate matter. Short of removing the drive motors, cleaning them and removing every hydro line has anyone done this extensive clean? My thought is to rig up a recirculating pump system and running diesel fuel through each line and then blowing them out with compressed air. I would also do this with the oil cooler and control valve. Am I over thinking this? Is some metal flake normal? I hate big projects that I make life harder on myself than I need too. What say you? Thanks in advance.
