Hi everyone
I have a 97 753 with the Kubota diesel, sits around alot with not alot of use. Fall of '09 I lent it out to relatives. When they were loading it they said it wouldn't drive straight, had to be full stick on one side and actually feather neutral/reverse with the other. Out on the job site the complaint was that it had strange steering response, but they couldn't be specific as they were not familiar with this type of skidsteer. So I chalked it all up as pilot error ;-)... Winter of '09 I wanted to move some snow, started it and let it idle for at leat 15 min, then headed for my driveway. About 100 feet later it began to slow down, but the engine was laboring hard against it, was as if I was stepping on brakes and full throttle at same time. I let up on the sticks and the engine went back to its normal unloaded state. Start off again, seems ok, then after 20 feet starts to grind to a halt with some pump/drive whining. Got out and noticed a trail of hydro fluid leading back to a puddle where I had let it idle and warm up. Parked it and figgured I'd find the ruptured line another warmer day. Today ... replaced missing fluid (about 2 gallons) lifted cab, started it up.. and nothing.. no leak, no broken lines! Ran the bucket up down, tilt, etc... all seems fine. Backed it up, all seems ok... then drove it about 100 feet and it starts to bog down again, let up and it recovers, moves fine for 20 feet then bogs down and some whining from the pump/drive. Still no leaks! Got the tires off the ground and isolated this to the left drive, will actually kill the motor if you stay on it and don't return it to neutral. Seems to be both foreward and backward, and does make a whining/groaning sound in the hydraulics as if it's laboring to turn those wheels. Inspected chains, wheel bearings... seem free spinning and undamaged, oil level ok. Read oodles of posts, could this be filter blockage, or should I prepare to get involved in the pump/drive? Thanks for any advice you may have!
