smokey196240
- Joined
- Jan 6, 2014
- Messages
- 7
my BICS light when i start it are all green but then fade and blink no bucket or lift arm will drive back and foward any help out there with this
The fade you describe sounds like you have power loss. Check our fuses to see if the connections are corroded.Does your machine drive back and forward with the lap bar up? With the key on and the engine not running, do you get BICS power and seat lights when you're in the seat and the key is on? Does the BICS power light stay green until you put the lap bar down? Does it then go dim or out when the lap bar comes down? There's more info based on what happens to the lights under these conditions.---Bobbie-G
