Bobcat Skidsteer Forums
753 bucket crown action hoses in rear, how to remove?
Reply to thread
Message
<blockquote data-quote="desross" data-source="post: 98681" data-attributes="member: 8399"><p>hi there thanks guys i got into mind today, hose/steel pipe joiners are behind the hinge of door.this is what i did remove hoses from where they hit steel pipes on arm, mark with pen which is which, tie string on so you can use string as draw wire to put new ones back on. 1.. take off metal bracket that holds all the electrical/fuse holders etc on back right ( two bolts ) 2.. take out water overflow bottle and bracket holder this gives you good access. 3.. undo bolt that holds steel pipes on wall where water bolt was. i was then able to push down the hoses and string from the top and poke out the back of engine and was able to undo hoses . ( note: i took off pipes at valve bank this maybe necessary to give you more movement, but you may not have two. try doing it without removing first i had already removed these but may not be necessary. not as bad as what i thought it was going to be. hope that helps.</p></blockquote><p></p>
[QUOTE="desross, post: 98681, member: 8399"] hi there thanks guys i got into mind today, hose/steel pipe joiners are behind the hinge of door.this is what i did remove hoses from where they hit steel pipes on arm, mark with pen which is which, tie string on so you can use string as draw wire to put new ones back on. 1.. take off metal bracket that holds all the electrical/fuse holders etc on back right ( two bolts ) 2.. take out water overflow bottle and bracket holder this gives you good access. 3.. undo bolt that holds steel pipes on wall where water bolt was. i was then able to push down the hoses and string from the top and poke out the back of engine and was able to undo hoses . ( note: i took off pipes at valve bank this maybe necessary to give you more movement, but you may not have two. try doing it without removing first i had already removed these but may not be necessary. not as bad as what i thought it was going to be. hope that helps. [/QUOTE]
Verification
Post reply
