I'm having trouble finding a video on how to change the parking brake solenoid with the spring operated pin. I can't even find the procedure in the operating manual. Help
It should be in the manual, lift the cab, remove the 2 bolts holding the coil on, slide up and out, slide new coil on, plug in, done. The spring should only push the wedge down into the disc t lock it, the coil pulls it up and holds it in place.
