751C PugBobcat
- Joined
- Feb 3, 2020
- Messages
- 4
Hi, I picked up a 2000 751C with the Peugeot engine not running. Turns over fine. Did the timing belt, new glow plugs and had the injection pump and injectors serviced. No problem priming it and bleeding out the air from the filter and pump. Timing is spot on. Tried a shot of ether and a bit of white smoke comes out but won’t start. Compression is 300 in all 4 cylinders so I think it should still at least start. Fuel is good, filter is good, motor doesn’t bind at all. Machine has 2100 hours on it and seems legit. Guy I bought it from said it likely needs rings. I’ve tried almost everything and it just won’t fire up. Am I wrong about the compression and it needs a rebuild? Thanks in advance. If it needs the motor pulled I’ll have some more questions since I read it’s better to leave the drive pump installed. 751C Pugbobcat
