Bobcat Skidsteer Forums
751 with 4 cyl Kubuto engine rough when warm
Reply to thread
Message
<blockquote data-quote="ddsprint" data-source="post: 23514" data-attributes="member: 2234"><p>sounds like the motor is just wore out, like was stated earlier, compression test will tell, which one is it, a 1702, 1902 or 2203, for about 2k in parts and machining you build a new motor, 400 for machining and 1600 in parts, pistons, rings, bearings, gasket, the parts are not the cheapest, but it is a deisel, I will say that they are not that hard to rebuild, just a thought, let us know your route or decision, thanx</p></blockquote><p></p>
[QUOTE="ddsprint, post: 23514, member: 2234"] sounds like the motor is just wore out, like was stated earlier, compression test will tell, which one is it, a 1702, 1902 or 2203, for about 2k in parts and machining you build a new motor, 400 for machining and 1600 in parts, pistons, rings, bearings, gasket, the parts are not the cheapest, but it is a deisel, I will say that they are not that hard to rebuild, just a thought, let us know your route or decision, thanx [/QUOTE]
Verification
Post reply
