I picked up a 1998 751 with the Peugeot diesel that isn't running. Last known issue was the rancher was bringing a load of gravel back to the barn and it just died. Rancher has since passed as well. Guy I bought it from bought it second hand with the idea of getting it running so it sat for another couple years. Needles to say, what actually happened to it has been lost. I was given a bunch of receipts and workorders from the past that show 2 inj pump replacements, and a new head (that one was interesting). But yet they couldn't get it running. Enter ME! First thing I check is the pickup tube in the tank.. rotted off. Ok, order some parts and temp bypass that getting fresh fuel from a can. Second, replaced the battery and glow plugs. Turns over well, glow plugs get wet, so it's getting fuel. But doesn't fire and pumps out Next step is to check the timing of the cam and inj pump. The service manual says to rotate the engine until the TDC indicator hole on the flywheel lines to the engine housing. But, being a 4stroke engine, technically, the cam could have two indexing points at crank TDC correct? Without pulling the valve cover, is there a good way to ensure the cam is indexed properly (both valves closed for cyl1)? Also, same goes for the injection pump as it has the same gear size as the cam. So I'd assume, two indexing points. Anyone have any pointers? Thanks, Todd.
