Bobcat Skidsteer Forums
751 needs to go
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 56012" data-attributes="member: 82"><p>Look up my profile and send me an e-mail, i can send you the section for the engine out of the manual. It's pretty easy. You can use some metric bolts and thread them into the cam and injector pulleys. If they and the hole in the fly wheel line up, it's correct.</p><p>Not sure about the hiss, id have suspected PCV valve or the sound of air by-passing the rings. Not sure you'd hear a head gasket leak like that or not....</p></blockquote><p></p>
[QUOTE="Tazza, post: 56012, member: 82"] Look up my profile and send me an e-mail, i can send you the section for the engine out of the manual. It's pretty easy. You can use some metric bolts and thread them into the cam and injector pulleys. If they and the hole in the fly wheel line up, it's correct. Not sure about the hiss, id have suspected PCV valve or the sound of air by-passing the rings. Not sure you'd hear a head gasket leak like that or not.... [/QUOTE]
Verification
Post reply
751 needs to go
