Hi guys, Got a 1300 hour 751 Pug (Iknow but it was cheap and I have put 400 hours on it without a hiccup till now). Ran perfect, was just grading my driveway, parked it, then went out the next day. Starts perfect but the bottom red light stays on and no hydraulics of any kind work. Tilt, lift, drive, etc is all dead as if it were electrical and someone blew a fuse. I checked everything visually and didn't see a problem. I also replaced the pressure sensor located directly under the hydraulic filter as it seeems to be a common problem and due to its age I felt it needed it anyway but that did not work. Fluid is full. Filter has about 250 hours on it. I have not changed the drain case filters but wasn't sure if they could kill the system. I took the plastic cover off the right side of the engine (drive belt I assume) and it feels tight. I am mechanically inclined. I rebuilt by lift and tilt spools and fixed the detent float functions without a problem and those have been working good for the last 200 hours so I can work on this ok but I am not a great troubleshooter as I am still learning something new everyday about he hydraulic side. All the lights are on beside the seat when the engine is running and the seat bar is down. Am I missing something here? Is there any other sensors or something electrical that would kill the system? Could it actually be a stopped up filter with 200 hours on it? If you guys can tell me anything else to check I would greatly appreciate it. This forum is awesome for info and I have learned more on it than any other forum. Thanks in advance. Jason
