Bobcat Skidsteer Forums
751 Bobcat
Reply to thread
Message
<blockquote data-quote="rbryant" data-source="post: 29420" data-attributes="member: 2300"><p>The filter was changed about 25 hrs back and the temperature here is still in the 50-74 F range. Yes Tazza it does do ok after it is first started and warms up a bit. But it might be a bad sending unit. I will check that after this rain clears. I will probably go ahead and change the filter as that is easy enough to do. Thanks!!!</p></blockquote><p></p>
[QUOTE="rbryant, post: 29420, member: 2300"] The filter was changed about 25 hrs back and the temperature here is still in the 50-74 F range. Yes Tazza it does do ok after it is first started and warms up a bit. But it might be a bad sending unit. I will check that after this rain clears. I will probably go ahead and change the filter as that is easy enough to do. Thanks!!! [/QUOTE]
Verification
Post reply
751 Bobcat
