Thanks alot for the info, as the local bobcat dealer told me it was better to take out the whole skid with the eng & hyd pump. will let you know how I make out. Thank's again, GMRemove the flywheel, coolant lines, rear engine mount, then remove the bolts holding the enging to the bell housing mehind the flywheel. Lift out.
I have done this a few times.
Its easier to do it that way, but messier as you need to unhook the hydraulic lines.Thanks alot for the info, as the local bobcat dealer told me it was better to take out the whole skid with the eng & hyd pump. will let you know how I make out. Thank's again, GM
